Discuss Do i need access to under the house when fitting a new boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Cabunag60
I will be having a new boiler fitted soon, i can find only one access point to go under the house, do the engineers need to get under the house to fit a new boiler only?
The one access point i can find only lets you go under half way, there is another but not sure where it is, all the floors have that parkay flooring, thanks for reading this.
Probably not, but then again probably would.
Without seeing the job.........
Yes hard to say, i have fitted a boiler this week and have had a nightmare because i could nt get under the kitchen floor because its tilled. If you are lucky and its a like for like swap you will be ok , its when you are changing systems where the problems can start .
I`m sure the gas safe registered guy who does the job for you will know what to look for when he quotes for the job.
Reply to Do i need access to under the house when fitting a new boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and Iā€™m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler pump menu for either 70% or 100%, so, is the pump set at either one of two fixed speed percentages or does the pump actually vary speed, (modulate)...
