Discuss Do I need Air Admittance Valve?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jonjack
Hi
I did find quite few threads on this already here but not one that answered my question.
I have a 2 story-semi with 2 existing upstairs toilets currently discharging into a singe exterior vented stack.
I am fitting a new WC in downstairs cloakroom and am intending to run the new waste into the base of the existing soil stack by using a triple socket branch.
Do I need an Air Admittance Valve in the downstairs cloakroom?
Also, is it acceptable to just join up the waste from the small basin I am installing in the cloakroom into the new waste from the toilet?
cheers
Yes will be fine to run a new toilet in to the stack without extra vent as it is already vented. Also fine to run basin waste into it aswell
it's only if you have a completely new soil run when you would need an aav. as plumber0808 said no need as you are joining to an existing vented stack.
Reply to Do I need Air Admittance Valve?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
