Discuss do i require heat leak radiator in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
connecting free standing woodburning stove to indirect cylinder, by gravity, do i need to fit heat leak radiator?
Reply to do i require heat leak radiator in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What do you think?
