Discuss Does Anybody know what this device is on the cold water inlet to my combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I was wondering if anybody could enlighten me as to what the device shown in the attached picture is which is sited on my combi boiler cold water inlet prior to the junction for the filling loop.
My current thoughts were some prehistoric water filter / scale inhibitor.
Other thoughts were pressure reducing valve but it doesnt look like any others i have seen.
Regards
Paul S.
Hi Chris,
Its a Worcester Bosch 28Si Mk2 which has been there for about 10years, but this was originally in place for an older combi boiler ( the make of which escapes me but french I recall ).
Regards
Paul S
Hi Chris,
Thanks for the reply.
I remember now the original boiler was a Chaffoteaux & Maury Combination Boiler.
I was contemplating removing it ( no objection to replacing it with something more up to date / tidier ). This is because I want to install a Fernox TF1 Total Filter in the Central Heating return. The pipework and location of the "restrictor" is making locating the filter at the ideal point tricky.
Cheers
Paul S
Could be an old type scale reducer, if its on the main, used to put silfoss crystals in them .
Reply to Does Anybody know what this device is on the cold water inlet to my combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Combi boiler and, a few minutes ago I turned on the hot tap in the kitchen and the water was far from hot. In fact, it was decidedly...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
Hi, Just checking I'm not talking rot. Today I visited a house with a Baxi 228 combi boiler. The technical spec for the DHW output is shown in...
1K
