Discuss Does mdpe need to be insulated as it comes up to the surface from 750mm? in the USA area at PlumbersForums.net
Hi, does the mpde supply need lagging as it comes back up to the surface from 750mm down and if so what should I use?
Also part of the run can be along a wall to cut down on digging, will armaflex be ok to insulate it?
Thanks in advance!
Mike
Insulated and in a duct
Not sure if the type of insulation is specified.
Check with your provider? I assume they will want to sign it off
Indeed it does to comply with the building regulations as below . Kop
That's brilliant, it's just a supply running out to our garden room but I want to make sure it's done properly. Will run an insulated duct up under the garden room and another up the wall outside the house. What lagging would u normally use? Was thinking 25mm armaflex or is there a better product to use?
Thanks, you can tell I only work on boilers!
You can do it externaly if you use one of these Mike
[automerge]1586670181[/automerge]
Armaflex is fine for the insulation Mike . Regards kop
Reply to Does mdpe need to be insulated as it comes up to the surface from 750mm? in the USA area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
