Discuss Does sentinel x800 need neutralising crystals ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dholi85
Basically what the title says.
Does sentinel x800 need neutralising crystlas?
no, its not an acid type cleaner. use as instructed on the bottle and you will be fine. If you want to be doubley sure test the ph levels at the end of the flush are the same as the cold water mains ph.
No but same thing as AW says get the pH right or stick a tds meter on the drain off when your flushing it out to make sure you get it all out.
Reply to Does sentinel x800 need neutralising crystals ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, new to the forum. Ive come across a commercial plant room with around 500KW of boilers where the condensate terminates outside about 4...
Hello I’m hoping for some perceptive / input as I’m a long-distance landlord trying to unpick the best thing to do. Gas safety certificate was...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hi all We noticed water suddenly backing up through the pipe for the dishwasher drainage pipe yesterday - first time this has happened. When I...
My Mother-in-law was quoted £1,000 by British Gas to do a power flush on her system as her rads aren't performing well. I was wondering, as 4...
