Discuss Domestic gas appliance in commercial property in the Gas Engineers Forum area at PlumbersForums.net
If a domestic boiler/gas appliance is in a commercial property, does this mean a gas engineer would need commercial tickets/qualifications?
If the installation is commercial, then yes.
Up to U16, up to 0.035M cubed up to 35mm pipework, is domestic. The volume includes the primary meter.
Others will interpret the rules differently so I suggest you read them yourself and decide.
IGE/UP/1B.
It all depends on what your doing
Servicing no providing it’s a stnd domestic flue and your not tt the whole line you can do a boiler tt
If your replacing if there’s a local isolation valve and from that to the boiler is under the domestic regs eg 0.035m3 then your fine
Reply to Domestic gas appliance in commercial property in the Gas Engineers Forum area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
