Discuss Double check valves ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
townfanjon
Subscribed
Guys , I look after a large dentist and the waterboard have done assessment / check this afternoon and want some ECED valves fitting , I have never heard of them but pretty sure they are just double check valves, does anybody know if they are a specific type of valve or just the usual double check valves.
Cheers in advance
Two types of valves, EC or ED, both forms of double check valves
Cheers Craig looks like the manager has given me the wrong info , she said he wants eced valves not ec or ed valves lol wondered why I had never heard of them .
Not for a steam steriliser is it?
Not sure pal , the manager just has a list of stuff he wants doing , going down in the next few days .
One remark made me laugh , one of the toilets has a dudley turbomaster syphon in it ( I fitted it ), no over flow on the bottom of the cistern and he said the place could flood if the ball valve failed
Reply to Double check valves ?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace the double-check/non-return valve on the pipe that goes out to the back garden tap under the sink. I got the correct replacement...
R
I just had installed a Navien NPE-2 with built in recirculator pump. I have a dedicated return line. The check valve for the recirc is built into...
Rogelio
R
G
Hi, I have recently had a water board inspection This is what the report said about the filling loop on our press unit for a biomass boiler…...
1K
Hi everyone, Is this set up correct: Attic stop valve turns off the cold water to my bathroom (I think it is the rising main in the attic which...
Hi all, I’ve a customer with a failed double check valve on a water softener, it’s 22mm compression but with a far larger bore than the usual...
