I'm going to fit a shower pump to the hot water pipe highlighted in the attached image. Just wanted to double-check my thinking: there's a valve on the cold feed to the cylinder so if I shut that off and run a downstairs hot tap until nothing comes out is that enough to empty the pipe I'm fitting the shower pump to? Or do I need to drain the cylinder a little bit as well? Is there anything I'm overlooking?
Thanks,
Nick
Thanks,
Nick
