- Messages
- 2,126
I need to connect a Dish Washer waste to an Iron Stack and was wondering if I have to buy something off 365 Drills or if there is something out there I can use to drill and attach the Boss strap without much probs
Discuss Drilling Hole in Iron Stack? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
There is a cast clamp on made by fixacon ...bergin products mke a cheaper version when used on cast stacks you need to use a rubber gasket ring....regards Turnpinunk:isnt there a special boss adapter aswell? one the tighten ups around it??? as you cant glue onto it
Just hit it with ballpein haller , perfect hole. Usually about 4"
Reply to Drilling Hole in Iron Stack? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
