Discuss Drive couplings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
CXR100
why don't they snap when the oil pump seizes ? ive had one the other day , oil pump completely gone, probably leaking aswell as I had to change bearings in motor as it was a bit hard to turn , but drive coupling was fine, I don't get it why they don't snap like a shear pin on a machine? cant make the motor much good that they don't??
If they made the drives able to snap if the pump seizes, then the drives would break too easily in normal use. The initial start of a burner motor is hard on the drives even when everything is working nice and free
Motors are designed for free running speed not for torque. Its torque thats needed to be able to shear something.
Reply to Drive couplings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all - hoping someone knowledgeable can help as I'm super confused by this.... I have a standard system / gravity fed boiler, large cold tank...
Deleted member 120897
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
Hi. I have an issue with my Ideal Logic+ System S24 boiler which I hope someone can help with. Below is as much detail as I can think of. The...
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6...
