Discuss DROP IN SHOWER FLOW/PRESSURE from Indirect Unvented Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
We had installed Indirect Unvented Cylinder(300L CentreStore) 3 years ago,as we had poor shower head pressure/flow with our Combi Boiler.
Lately we feel the shower flow or pressure has reduced.Previously we could run two or more showers/tap at same time,but nowadays once we have a tap open downstairs the shower flow reduces to a trickle.
What could possibly be the reason?
We get the combi-boiler and the Cylinder serviced annually and it is not due for another 4 months.
Any ideas?
Many Thanks
You noticed any change in your mains pressure?
Has the cold mains flow and pressure altered at the kitchen tap , i.e road been up , new houses close by etc etc
no,the mains pressure hasn't decreased.
may I add that we noticed it more after coming back from holiday(shutting off the combi boiler for 10 days)
Could be the inlet filter is blocked if you can manage until it's serviced tell them then if you can't call them out next week etc
Reply to DROP IN SHOWER FLOW/PRESSURE from Indirect Unvented Cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
R
Hi, am getting our bathroom updated and local company suggested ditching our traditional attic CW tank/vented cylinder and pump for the shower and...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
