J
James05
First time on the forum and looking for a bit of advice. We have converted a large workshop area attached to our house and looking to plumb in the central heating. I'm planning to put in a flow and return system with 22mm main pipe and 15mm Spurs to the radiators. The main pipes will run above the suspended ceiling (concrete floors) and I,m looking to drop the Spurs down through the stud walls to the radiators which will be a drop of about 7' . My question is will the flow in to the radiators be ok with the main pipes being 7' above as usually the main pipes run below using convection to get the hot water to rise in to the radiator. Secondly as the pipe work will be up high should I put some bleed valves in to avoid air lock problems?
Hope someone out there can help.... Many thanks
James
James
