Discuss Dual fuel radiators. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dlt27
Hi any advice will be appreciated. I am an electrocian so please go easy. A customer has had a dual fuel radiator fitted in their bathroom. All i wanted to know was if the c/heating is turned off how do you stop the heating element heating the water in the flow and return pipes. Is there any way some sort of interlock can be fitted and if so how would it be wired. ie through a time clock and room stat. Thanks in advance.
When the heating is turned off the pump is not running so any heat in the bathroom rad will stay there, as it is not getting pulled around the system
When using it on electric make sure you turn off one side of the towel rail.
Hi dlt27 welcome into non electricain land - you are welcome I think I have your question squared up. It will be a good idea for you to put up a diagram or pic - then we can all have a look
- as its not all circuit diagrams on here CHK -
Reply to Dual fuel radiators. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I have an Eastbrook Hurley towel radiator and fitting it as a dual fuel, with pipes coming out of the wall. I've been advised to...
As part of deep house renovation, planning to install wet ufh on the ground floor, and radiators on upper floor. Two bathrooms will have both...
Morning all, Can a towel rail thats been converted to Duel fuel trip the boiler RDC. We have just had a new radiator fitted and it's heated by...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
