Discuss Dual fuel stove with boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nulook
Advise please
On central heating feed pipe from the stove, would I be correct in saying--vent pipe then 150mm after cold water feed (from tank in loft) then pump, or should it be cold water then vent?
Any help would be appreciated.
Nulook
Reply to Dual fuel stove with boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I need to replace the kitchen tap, all my neighbours have two single taps in their kitchen and bathroom whereas I have a single...
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each...
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated...
Hi all, Just a quick question. I have a log burner and a gas boiler on a dual fuel system (Central heating and Hot Water) either can do both. The...
I have a thermal store heated by a boiler with its own thermostat. I also have a stove with a back boiler. The stove heats water in a separate...
