Discuss Dual heating system with upstairs and down stairs thermostats in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I have a dual heating system ie separate thermostats for upstairs and down stairs, my question is why does my upstairs bathroom radiator come one when I turn my downstairs heating on ??
Surely this should come on when I put the upstairs on ??
Possibly piped wrong ? , but could also be it's connected to the primary circuit so when the hot water is called for the towel rail or rails get hot ? often done like this for summer use when the heating is set to off and not needed , to dry towels
I’d understand that if it had towel rail but just a normal radiator lol I’m going for piped wrong as it’s a new build
Reply to Dual heating system with upstairs and down stairs thermostats in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Hi. Turned my heating on for the 1st time today, i bled every radiator as haven't done it since last winter. upstairs worked fine but an hour...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Hi. A new house regulation for a 2 zone heating system because it's bigger that 150sqm. I'm I right in saying zone 1 should be all of the...
2K
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft...
