Discuss Dual heating system with upstairs and down stairs thermostats in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi I have a dual heating system ie separate thermostats for upstairs and down stairs, my question is why does my upstairs bathroom radiator come one when I turn my downstairs heating on ??
Surely this should come on when I put the upstairs on ??
Possibly piped wrong ? , but could also be it's connected to the primary circuit so when the hot water is called for the towel rail or rails get hot ? often done like this for summer use when the heating is set to off and not needed , to dry towels
I’d understand that if it had towel rail but just a normal radiator lol I’m going for piped wrong as it’s a new build
Reply to Dual heating system with upstairs and down stairs thermostats in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
Hi, Later this year I am going away for a 2 week holiday and as the weather will be warm there is no need for the heating to be on and arguably no need for me to needlessly heat hot water. My intention was to turn the boiler off along with the mains water when going away. Now, I have heard...
