Discuss E911 fault - what is this stuff? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Issue with Samsung air to water heat pump
Over past 6 years we constantly get E911 faults, slow flowrate and temp dropping below 10c in the system.
The pic below is from the external heat pump unit which has a filter attached to it. When tested we are been told this is not magnetic as we originally thought it might be from the towel radiators that are steel (corroding?) Whereas pipe work is copper and main rads are aluminium. Anybody have any ideas?
System defo need flushing and cleaning as it’s out your rads
Could be the alu rads still having sand in them from casting etc seen that many a time and normally say in the instructions to flush before fitting
Reply to E911 fault - what is this stuff? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6...
I have a Vaillant Ecotec Plus 424 boiler in a closed heating system with 13 rads and 4 towel rails. Rads are steel, pipes are plastic kind of...
2K
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
Hi, we had UFH installed dowstairs in our house recently, and I'm not 100% sure that it's connected correctly. I'd be grateful if someone could...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need...
