Discuss Easy install stats? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
Hi all.
I've got a Worcester 28i junior with a mechanical clock and room stat.
Wiring wise, what would be an easy swap over to a more modern programmer/stat?
I'm not to used to wiring up.
Any advice appreciated.
Comfort II
£200 for that, blimey. Any decent ones at a reasonable to use on my phone? Or are the a complicated install?
Have a look at nest, tado, hive
Never really got my head round all the open therm and weather comp stuff so I'm unsure as to what is compatible with the 28 junior.
Tbh it should but I've never fitted anything but the comfort II so can't answer that best to ask Worcester tbh unless one of the guys have fitted one
The Sally's WB unit might fit in the front.
Cheap and cheerful
Reply to Easy install stats? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
