Discuss electric shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
it could also be dirt in the inlet filter, quite easy to strip and check that, depending on the pipe layout disconnect the inlet and connect it to a bend and a bit of pipe, then get someone to turn the water back on and see if you get full flow into the bath or shower
Reply to electric shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
