Discuss Electrics on boiler swaps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Millsy 82
Do I have to get a sparky in to do the electrics if I'm swapping a boiler? I'm only talking 1 off 1 on no alterations to the electrics, on a complete system I will get someone in but it's just a pain trying to arrange one when I need them.
Have to be honest I've never got someone in unless previous wiring was a mess. Be jealous guys I actually know a sparky that understands wiring for heating systems AND enjoys working on em
Most of the companies I've worked for got me to wire the s/y plans then got a sparks in to test them. But it's more of signing things off do they have to sign off electrics on boiler swaps?
Where i stay there a few one man band sparkys ( older gentlemen ) and none of them have there 17th edition , ( its not well known that they dont by locals but i know ) granted they dont take on any jobs that require signed off so the few sparks that are select approved are raking it in, the guys who arent are still well known in the town and advertise as electricians and the only thing they have is they deem themselves compitent, i think this happens alot so we are as much compitent as these guys, but rules are rules and weve to abide by them ,
you are fine with a straight swap imo. just check the supply is correct and the earth is present, any concerns get a sparks in to test and certifiy.
Reply to Electrics on boiler swaps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
