Discuss Electronic scale inhibitor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Titanium Trades
Installing an electronic scale inhibitor, done plenty of in-line ones but the question I have is with the electronic ones can I wrap the wires around the hot cylinder outlet or can it only go on cold feeds?
Thanks in advance.
The "theory" would be it converts the water flowing thru into protected form that will not stick ,
( but IF the electronic ones are any good , is another debate )
Do instructions/website give any best placement advice for particular design ?
Looking at the one on ScrewFix... got great reviews but no install info on the details, didnt want to buy before finding out it can only be fixed to cold feed.
Reply to Electronic scale inhibitor in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
