Discuss Elevated moisture on floor despite pipe pressure test ok in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Bill D
Hi. I had a pressure test done on the toilet connection tap. Test showed no leak. However, thermal imaging showed elevated moisture levels around the tap (& toilet (on the floor).
I am wondering if it is possible that there could their have been a long time (ie years) slow leak from the pipe / tap / toilet base despite the pressure test showing no leaks from the pipe????
Could be the drainage side eg waste pipes ?
Reply to Elevated moisture on floor despite pipe pressure test ok in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
