Discuss Eurometers E6 SC - How to gas rate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jerry
Hi All,
Some wisdom, please
How do you gas rate these little meters?
Google brings up nothing and I couldn't see anything in the Tech Bulletins.
Cheers,
J
Don't get many of them down this way. Think that one changes every couple of seconds as apposed to the other similar meter which updates every 30 seconds.
Thanks Sam,
It definately did not change. I think there is a sensor on the RH side that detects light/movement. I figure this must shut the meter display off when the meter box is closed to save power. I think this is faulty
J
Reply to Eurometers E6 SC - How to gas rate in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for some advice on my little bathroom project. I took the bath out. I got a shower jacuzzi thing. The base has 2 wheels in the...
Sonya K
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
