Discuss expansion vessel pumo in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hellfire
after some advice
need a new pump for re pressurising expansion vessel which one would you recommend
also do you use a pressure gauge or pump to test vessel
Mine is a usual car type double foot pump with an adapted 2.5 ish meter lead , so its solid on the floor as you pump it , but I do like the type Darren ^^^ uses
I got the Regin as well and also a small digi pressure gauge from Halfords (I think)
Used to use a double cylinder foot pump, but the short hose made it hard work on the arms
A stirrup type pump is the way to go
I use the Regin foot pump one too. I won one of the Regin rechargeable pumps its very noisy. I prefer the good old foot pump.
I won the Rothenburger cordless pump in the xmas raffle at M&R's (local supplier) used it twice and put it back in it's case & retired it to the back of the lockup. Absolutely useless, a 5" hose that doesn't reach the valve, battery lasts about 1 min and it's really noisey. I'll stick to my Regin stirrup pump.
Regin stirrup type for me to, just use a tyre pressure gauge for testing the vessel
Reply to expansion vessel pumo in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
