Discuss External kitchen drainage - (large) leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi - first time poster so apologies if this isn't in the correct forum.
A couple of days ago I noticed that my kitchen drainage pipe is overflowing if the water is run for more than 10-20 seconds. I'd assumed the chamber it flows into (grease trap?) was blocked and just needed clearing, but on closure inspection the paving around the drainage pipe look to be severely damaged.
In the second picture you can see a very small opening between the pipe and the brickwork. Looking down that hole, it appears that the water is actually flooding out of the drainage pipe and pooling directly against the base of my exterior wall before it eventually (slowly) drains away.
I've had a quick look in the trap and reached down approx 25cm into it, but can't feel any blockage. However, the water is definitely not clean, and is full of small bits of food, etc. Looks quite a lot like vomit.
Any advice on what to do about this (and how much it's likely to cost - we're in London) much appreciated. I suspect I'm going to have to get someone to rip the paving up and fully expose the pipework? Obviously having water pooling directly against the wall is not great, but can I expect there to be damage to the foundations? We had a survey done before moving which didn't pick up on any subsidence, cracks, etc. I'm concerned by the amount of white growth on the brickwork below the damp proof course.
I wouldn't think you'd need anything so drastic as removing paving etc. A good drain unblocker would be able to sort that for you through the inspection chamber. No idea about cost as I'm in Norfolk, sorry!
Drain just needs jetting get a local drain company in get a quote first look at reviews online also . Kop
Reply to External kitchen drainage - (large) leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had a potential leak in the island kitchen drain, but it's no longer an issue after using an auger through the clean-out pipe. The water seemed...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
Hello I am fitting a kitchen in a new room without services. Looking to tile the floor so everything under the tiles really needs to be fit and...
Noticed today that the ground looked damp around the outside of our Worcester Bosch Heatslave 25/32 External Boiler. Took the cover off and warm...
2K
