Discuss No more leak island kitchen drain after unclog in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I had a potential leak in the island kitchen drain, but it's no longer an issue after using an auger through the clean-out pipe. The water seemed to be coming out from the base of the pipe.
I've removed a section of drywall for inspection purposes. After filling both sinks with water and activating the garbage disposal, I observed a slow drainage. Around 30 seconds later, water began to emerge from the base of the pipe, forming a small pool in the drywall before eventually spilling over. Identifying the specific pipe responsible is challenging since the drain and vent pipes are in close proximity. Notably, I observed bubbles emanating from the vent side of the pipe during one instance, and subsequently, the small pool of water gradually subsided. Additionally, I observed a small hole in the vent pipe, but there are no apparent signs of water emanating from it. Any idea where the leak might be?
Can anyone help with this question about the sink?
Reply to No more leak island kitchen drain after unclog in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
