Discuss F9 on boiler, fires up after reset only in the USA area at PlumbersForums.net
I have a Glow-Worm Ultrapower sxi. I am used to sorting out an F9 by topping up to about 1.5 bar, then the boiler fires up. However twice now I have found an F9 and after pressing the reset button the boiler fires up without any top up and the indicated pressure is >2bar. Is it possible that there is too much pressure in the system and the boiler will display F9 to indicate that as well as too little?
Can be a few things, might need someone in. Might be equivalent of Vaillant f75.
Reply to F9 on boiler, fires up after reset only in the USA area at PlumbersForums.net
Just been to a nightmare of a job! Had to carry out a service on the 2009 British Gas 330 + (GC: 41-019-11) It's a Glow Worm boiler. The boiler...
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating...
the pressure of my boiler looks unstable After i re-pressurize to 1.5 bar, using tap is ok without problem. but when turn on the central heating...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
After researching as much as I can to sort this problem, I keep reading that if your Ideal boiler has an F1 code and the pressure is low, it needs...
