Discuss Fan Flue Boiler with good internal fitting arrangements in the Central Heating Forum area at PlumbersForums.net
centralheatking
On behalf of a friend we are looking for which fan flued ng combi or system boiler has a good fitting from inside only. The outside is in Bath and 3/4 Floors up but the outside is above the River Avon
so no ladders too high and no scaffold...unless expensive suspended stuff. around 20kw to 30kw
he will need two per floor x 3. Thank you in advance. centralheatking
Ideal Logic Max Mr C ? described below so is doable . Kop
Don’t the gas safe regulations insist on sealing the flue to the external brickwork though? This prevents flue gasses from entering the cavity? Will this be possible? I suppose you could take extra bricks out from the inner skin to allow access? Maybe??
drop a rope outside side the flue over the rope and tie a screwdriver in the end and then pull the flue up through the hole sorted
Reply to Fan Flue Boiler with good internal fitting arrangements in the Central Heating Forum area at PlumbersForums.net
I have a 3 port valve Y plan system, with a hot water tank in airing cupboard and a cold water feeder tank in loft. I want to replace the old 25+...
2K
I have an Alpha Intec boiler installed on my loft wall. The flue goes horizontally from the top of the boiler and passes through the wall, exiting...
6K
Hi, Any help, advice or personal experience appreciated. We are supplied by a lead pipe but on a shared supply. I am about house 4 out of a run...
3K
So there's a few estates scattered around my way that have the dreaded powermax boilers. All of them are installed in the middle of house in a...
Burger
B
Hello, from South Devon. Firstly - I'm not a Gas Safe RGI. I'm considering my options to replace a 23 year old |Ideal Classic FanFare 50,000 kw...
3K
