Discuss Faulty PCB classic symptoms? in the Central Heating Forum area at PlumbersForums.net
Hi guys
What are the classic fault symptoms of pcb issues on baxi/potterton?
Though I can get some heating and hot water out of mine, it's still going into reset mode when I switch it in certain circumstances.
I did have pcb fault lights ta while back but now just the one red light, but boiler kicks back in when reset.
PCB faults are usually where you end up when all other possibilities have been eliminated.
Yes that where I am... And looking to try a replacement.
Looks a simple job, and have purchased a refurb, though my original has a extra light for condensate pump issue the new one doesn't, they are saying it's the right one.
Reply to Faulty PCB classic symptoms? in the Central Heating Forum area at PlumbersForums.net
