F
Foston
I have a PN16 Gate Valve that turns but does not stop. i.e. it simply keeps turning. Is it possible to replace the centre screw mechanism [even if I need to buy a complete valve to obtain the spare part] or will I need to replace the whole valve. The question arises because I cannot see how to easily cut off the supply of water to the pipe [cold] and I thought that freezing the pipe may be an option, in which case changing only the centre of the valve seems a possible safe solution.
