Discuss Faulty timer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ian
Hi. Have a greenstar 30cdi with a honeywell 9400c timer. I currently have no heating but I do have hot water. I had same issue a while ago which I resolved by turning the back-light off the timer so guessing it was failing then. Any thoughts? Also does anyone in West Yorkshire have a spare I could buy? Cheers
I have some programmers Ian , however as Murdock above says it might be better to get somebody to look first , however it does sound like there maybe something wrong with it .
Cool. Do you have a honeywell 9400c. Could pop it on and see if it does the trick. Cheers
Reply to Faulty timer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
