Discuss Faulty UFH mixing valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Please advise,
With the UFH mixing valve set to give 45^ Flow temp To the manifold circuit am I right to expect this temperature To remain constant whatever the flow rate, if any, there is to the manifold circuits?
Within reason yes but if your using a remote mixing valve don't forget about temp drop the further it is from the manifold
Reply to Faulty UFH mixing valve? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
