C
Chris_B
Hello,
I am going to fit the Fernox TF1 filter to a relatives C.H. system tomorrow, I understand that I have to fit this to the return pipe on the C.H.
I think the C.H. pipes on the boiler are 15mm, but the Fernox TF1 comes in either 22mm or 28mm isolation valve fitments.
Now, this does seem obvious, but when I fit this, I will need a reducer coupling, from 22mm to 15mm to adapt to the existing pipes. but I am still unsure as I think the standard size for C.H. pipes are 22mm.
The isolation valves on the Fernox TF1 are stamped '22mm' on them but the valves are not full bore, as they look reduced.
Is 22mm the size of the valve pipe or the copper pipe that it fits?
Any help with my confusion much appreciated
Chris
Chris
