Discuss Ferolli Optima 701 Advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Matthew91
Needing some advice regarding a ferolli optima 701
I'm a gas safe engineer, but I've never had this issue and I wanna see if anybody else has possibly had it before I change the board on Monday.
So the boiler broke down yesterday, permanent pilot stayed lit, all boiler electrics failed however fuse at spur hadn't blown. Isolated and checked the boiler, 2amp fuse on the board had blown and I was getting 33mOhm on the pump, disconnected the pump from the board and replaced the fuse and the fan kicked in with the fuse being fine. Replaced the pump today and the boiler is now not blowing fuses and pump, fan, aps and everything working fine.
However, there is still no LEDs on the PCB fault display. Wondering if it's possibly damaged the board at the same time. Was a glass fuse and it completely shattered it when it blew.
Manual says if LED 1 (Power) isn't lit to check for blown fuses or the supply as there isn't a supply to the boiler, but the fan etc is running and I'm still getting continuity across the fuse with 240v travelling across it so it's definitely getting a supply.
The boiler also ain't allowing the sparking sequence to start, so the pilot won't light. If I light it manually using a lighter it's staying on but full burner won't kick in if there's a demand on.
I might be missing something really obvious here but I'm just needing a different opinion if possible.
Thanks in advance
please pm dan or lou with your gas safe no
@Dan @Lou
as we have a private gas safe forum
Yes. We don't get auto notifications of sign up info yet. Please pm me. I deal with them
Reply to Ferolli Optima 701 Advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Funny
    • Optimistic
Hi, I've got a ferroli 901 boiler, I initially thought the pcb was at fault so bought a new one and I'm having the same problem ( has been...
Hey. Got home from Christmas with family to find boiler isn't working, no lights on anywhere. Boiler itself is old but ok. There has been a leak...
I need some help with a Worcester Junior 28i gas boiler and I'm hoping someone here may have came across this fault before ... I have checked...
1K
Hi all, looking for some advice please. So I've got a 25 year old Ideal classic NF40 boiler. We live in a naturally warm house so only have the...
1K
Hi all, I'm really stuck with an issue I have with our soliud fuel back boiler system and my novice understanding is pretty much out of ideas so...
6K
