Discuss Ferroli f24 domicodens boiler showing F37 error code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wellington38
I am constantly getting the F37 error code on my boiler as detailed above on a daily basis now, this has always been a problem, but from the boiler doing this every 4 weeks or so, this is now happening every day. I am also getting constant air locks in the bedroom and bathroom radiators, which i then bleed to get rid of them before filling the boiler back using the 2 black taps underneath the boiler, until the boiler kicks in around 1 bar, then i turn them fully off. the heating will work for a number of hours, then the pressure drops and the warning light comes on again. However as i write this, there is now a slow drip of water from the kitchen ceiling, which i now presume is a leak in one of the pipes above the ceiling, have checked around the toilet and sink area which shows no visible evidence of leaks from those areas, the heating has been on for around 2 hours.
Phone a Gas Safe Registered plumber/engineer. Nothing you can do yourself on this one except poke a screwdriver through the ceiling at a couple of points (it saves the water building up and bringing it down)
ok thanks, will do this, meanwhile won't have the heating on as the water is obviously being forced out of a pipe under pressure, i 've checked the valves on all the radiators this week, a couple of them had slow leaks which was a factor in why the boiler was shutting down before, but these are now leak free which i'm assuming is why we now have a leak from the ceiling, thanks again.
Reply to Ferroli f24 domicodens boiler showing F37 error code in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ideal Logic Heat 15 System Boiler Hi. Just started to get an F3 Fan Fault on this boiler. On power up there seems to be a quiet thump from...
Deleted member 120897
Hi, would appreciate any thoughts on the below. I have an almost 10yr old Ferroli Modena 32S HE system boiler. (I am aware of their reputation...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
