Discuss Fga results are fine, IP is fine but gas rate is low in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Still learning gas work so be easy please
I was at a service with a tradesman today and the fga was fine so was the inlet pressure at meter but the gas rate came in at 20 odd kw on a worcester junior 28i
He gas rated with the tap open full, he told me the gas rate was low because the flow rate was poor
Could someone please explain how this works to me? And also what else could cause a gas rate to be low but fga and IP are fine?
So if what he says is true and fga is fine aswell as IP then the gas rate being a bit lower due to water pressure is fine?
Reply to Fga results are fine, IP is fine but gas rate is low in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
