Discuss Fiting a shower waste without a trap in the USA area at PlumbersForums.net
Hi All
I am creating an ensuite bathroom abd have to fit a macerator(i know i Know) the instructions require the shower waste be fitted without a trap (i assume it is for the flow rate of rh waste water) Any ideas on where to find this. I have been lookong at Mcalpine fast flow traps, would this be sufficent.
Thanks in advance
Reply to Fiting a shower waste without a trap in the USA area at PlumbersForums.net
    • Useful
My parents have a leak from kitchen sink. My dad removed waste trap and since refitted it leaks, but there wasn’t any kind of seal on it, I got a rubber/plastic gasket that seems To fit the trap but with it, I can’t get it to screw and lock back on (has lugs so locks after quarter turn. But...
Hi, As per title we have a regular smell from the shower trap. Clean the trap twice a week, had a cleaning rod down the shower waste pipe and no blockage. Used several different drain cleaners over time but smell returns (not always but often enough to be annoying). Seems to coincide with...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction with concrete slab subfloor. All of the waste pipes run in the concrete, and exit the property at the chamber as pictured, just outside the building...
In my last posting, I requested assistance in exchanging a waste that had been fitted using silicone, without actually removing the basin. Mission accomplished. However, I now have a further issue for which I would welcome any suggestions or advice. I decided to replace the McAlpine Pedestal...
