Discuss Fitting a bath to a tiled wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
As I cant get any more tiles the only way I can see of doing it properly is set the bath height, offer it into place and mark the wall, cut a line and remove tiles to fit the bath.And what distance do you have tile to tile now? And what would you have if a tile either side was removed?
Sorry, I understand what you mean nowYou will never slot bath into place tho mate...
Say you had 1680mm tile to tile but you cut tile out each side and you have 1700mm you still wouldn't get 1700mm bath in it due to the angle of slotting bath in.
Best bet is bath made to fit or a 1500mm bath with infill
Then I would change to... I’m not your man.It’s changed from got no money just need a bathroom to wanting underfloor heating, move this and replace that, concealed shower, we will get the bits from the internet just need it fitted.
I have lost all interest in the jobThen I would change to... I’m not your man.
I would explain that you either do it all supply and fit, or nothing. Puts the ball back into their court.I have lost all interest in the job
Reply to Fitting a bath to a tiled wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
