Discuss Fitting a heated towel rail in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello
I will be fitting a heating towel rail in a bathroom with plasterboard walls. The room is being tiled at the moment. I need some good fixings to hold the towel rail. I usually use grip it fixings but these might be hard to use with the tiles. Can anyone recommend some good fixings for the towel rail? Unfortunately I cannot find any wooden battens behind the wall, where the tile rail is going.
Many thanks
Paul
Cut the plasterboard out with a multi tool where the brackets are needed fix a piece of ply between the studs screw the plaster board back in place , tile over the area now the towel rail can be fitted and you are guaranteed a good fixing. Cheers kop
If you now have no choice if it has been tiled, then the top two brackets, or all could be done with the expanding brolly anchors.
Or there is another very strong toggle I once got a link for that has a solid bar, which is threaded for the bolt and this bar is connected to an outer flange. But the clever thing is the both parts are held together with a spring. Think it is German or Swedish.
Thanks very much.Yes it has already been tiled so I think I will go with the brolly anchors. Thanks for everyones help
regards
Paul
I did a search of this forum for toggles and found a thread I had been given the link to them. These are superb and will not fall into the stud wall if bolt is removed. They are very strong and the metal bar is heavy and has a good few threads for the bolt.
Schneider TPP Platti Plug cavity fixing - Edwardes
regards
Paul
The problem you now have with brolly anchors is that you'd need the right size to go through the tile, adhesive and the plasterboard. I would personally just use rawlplug uno's but if you're not confident with those then spring toggles on the top fixings. Have used brolly anchors before on plasterboard walls and they're brill, not used them on a wall after it's been tiled though.
To be fair though, I don't often use brolly anchors, if others say they'll be good then they'll be good ;)
The Brolly anchors are reasonably good for medium duty.
You need the shaft long enough for tiles and plasterboard as JCplumb said.
The grippers on back of the flange can be a problem as won't cut into and grip on the tiles.
And speaking of the flange part, it can be very weak and snap off, especially on some cheaper made brolly anchors.
First preference, take off the plaster board and install some noggins. Photograph and measure carefully for future reference.
Second choice, install the Grippits in the plasterboard before tiling then drill the hole through the tile in the right place when you arrive at that row.
With plasterboard providing the support, you want the fixing to be as big as diameter as possible to spread the load.
If you are only half-tiling the wall so the upper standoff (mounting) pillars are directly on the plasterboard, consider using a tile or a nice stainless steel washer as a load-spreader to avoid the pillar crushing the board on the bottom edge where the pressure is a maximum.
Reply to Fitting a heated towel rail in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
