- Messages
- 6
I have been asked to fit an external tap at a mental health facility to enable the external paths to be hosed down. What form of back syphoning measure is sufficient for this installation?
Discuss Fitting an external tap at a commercial premise in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
I used to work with someone of the same name (used to be a postal worker, then health and safety officer), anyway I digress, if it’s just to be used like a garden tap, then I think (although don’t quote me) it can be a double check valve. If it’s to used near a bin store, I think the fluid risk category changes to a 5. Best bet would be United Utilities water regulations department, as they enforce the regulations for your area. Alternatively seek guidance from Wateregs uk, or look in the water regulations guide.I have been asked to fit an external tap at a mental health facility to enable the external paths to be hosed down. What form of back syphoning measure is sufficient for this installation?
Made an appointment for UU on Monday and yes it is the same person, who are you?I used to work with someone of the same name (used to be a postal worker, then health and safety officer), anyway I digress, if it’s just to be used like a garden tap, then I think (although don’t quote me) it can be a double check valve. If it’s to used near a bin store, I think the fluid risk category changes to a 5. Best bet would be United Utilities water regulations department, as they enforce the regulations for your area. Alternatively seek guidance from Wateregs uk, or look in the water regulations guide.
I’ll PM you if that’s ok? Don’t want to let the cat out if the bag who I work for publiclyMade an appointment for UU on Monday and yes it is the same person, who are you?
Okay , not sure how private messages work but will try to find it.I’ll PM you if that’s ok? Don’t want to let the cat out if the bag who I work for publicly
Will do but my in house maintenance manager suggests that the attached makes it Class 5 because we would be fitting a hose union tap, what do you think?Let us know what UU says. I'd imagine that so long as it's intended for use with an above-ground hose (to be fitted with a spray terminal that shuts off when you release it as per Water Regs) and not connected to some kind of device for dispensing chemicals with the water, a DCV will be fine, but I'd like to hear it from them.
Reply to Fitting an external tap at a commercial premise in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
