Discuss Fitting an external tap at a commercial premise in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
I have been asked to fit an external tap at a mental health facility to enable the external paths to be hosed down. What form of back syphoning measure is sufficient for this installation?
I used to work with someone of the same name (used to be a postal worker, then health and safety officer), anyway I digress, if it’s just to be used like a garden tap, then I think (although don’t quote me) it can be a double check valve. If it’s to used near a bin store, I think the fluid risk category changes to a 5. Best bet would be United Utilities water regulations department, as they enforce the regulations for your area. Alternatively seek guidance from Wateregs uk, or look in the water regulations guide.
Made an appointment for UU on Monday and yes it is the same person, who are you?
Cat 3 aslong as it’s just washing down pathways
Let us know what UU says. I'd imagine that so long as it's intended for use with an above-ground hose (to be fitted with a spray terminal that shuts off when you release it as per Water Regs) and not connected to some kind of device for dispensing chemicals with the water, a DCV will be fine, but I'd like to hear it from them.
Will do but my in house maintenance manager suggests that the attached makes it Class 5 because we would be fitting a hose union tap, what do you think?
  • Table G6.1e.pdf
If you think about it though, and similar logic applies in the gas industry, it’s a commercial premise, but then installation is deemed as a domestic setup. However, as I said, this is why it’s best to seek guidance from united utilities - it’s their supply and they enforce the regulations.
Neil Foster and Ken Lacey (if they’re still there) are nice helpful gentlemen.
Inclined to agree with your supervisor, with some reservation. Do bear in mind that the document you show is industry guidance (i.e. the water undertakers) which can be over-ridden if the industry (in this case UU) decides. In practice, my experience with water regulation enforcement officers is they tend to be practical people with a common sense approach.
My vote is for cat 5 because, for example, someone might decide to stick the hose up a blocked drain in an attempt to clean it. A lower category might be possible but would require a proper risk assessment to justify it.
It's a very weird one actually. Because the tap itself has no backflow potential unless we already know what it is likely to be used for (which we do). Similarly, you could theoretically fit a washing machine valve with 3/4" thread without even a SCV in line (assuming the washing machine IOM states that no backflow protection is required - I always fit a SCV as I doubt any customer will ever bother to check) and then the customer could later connect a garden hose and use it to unblock the kitchen sink (cat 5).
IIRC if the hose union bib tap were internal (rather than external) to a domestic premises and perhaps used to fill a mop bucket, you could quite legally fit it without any backflow protection at all. Then, if a hose were attached, the need for a DCV arises as the hose is a new installation.
Reply to Fitting an external tap at a commercial premise in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
