T
Thedeester1
So I have been reading a lot. I have a vented Y plan system with a conventional boiler. Even when I set up everything with my thermostatic multi meter I think I am losing condensing at the boiler when I heat hot water. My current hot water loop goes through the pump then the 3 position valve, through the tank coil and then straight back to the boiler. When Im heating water the return to the boiler is often very hot. Would it pay to put a gate valve on the bottom of the water heating coil to hold the heated water in the tank coil longer???
