Discuss Fixing boiling water tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
I don't install them, don't touch anything involving elecs normally. I also have no knowledge of them or how they work or how to work on them.
But a customer emailed saying " I have a boiling water tap in my house which is running constantly - something to do with the filter. We have the replacement part to sort it out"
Presuming they do have the right part, is this something I/anyone with a spanner could do? I can fix normal taps and do most related basic plumbing nonsense.
It might just be getting too hot and venting through the tap. Otherwise, depending on manufacturer, you should be able to sort it.
It's basically a kettle that's always boiling so don't think it will be down to a filter (might be wrong)
If in doubt ring the manufacturer if it's quooker there very good and helpful
Reply to Fixing boiling water tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
