Discuss Flame failure after draining system in the USA area at PlumbersForums.net
Hi
I drained my heating system to replace a radiator and now ive got flame failure on the boiler (potterton promax fsb he). I've repressurised it and bled radiators. Any ideas?
Normally when a boiler overheats it makes strange noises, some hiss some bang and clatter, any of those? Often the aav is nipped up and air gets trapped in the back of the pump.
It lit for a few seconds then went out. I had a play with it and eventually it works. I'll guess it was an air lock. I've got a few radiators to replace so it's gonna be fun and games
If it is getting air locked shoot it up with mains pressure after you have finished. Connect hose to outside tap and to the lowest drain off with a jubilee clip. Gently switch outside tap not full on open drain off and check for leaks. Open bleed on bottom rad increase pressure and blow air out working upwards and away from induction point. Close off drain off. If you can see any aav tickle them whilst doing rads. Centralheatking
Reply to Flame failure after draining system in the USA area at PlumbersForums.net
I am having a problem with my main 24he boiler where the flame is constantly clicking on and off with the heating and when using hot water. Some...
Hi, I drained the the central heating, to remove a radiator. After refilling it, the heating now won’t work. It’s a combi . I’m getting this symbol
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber...
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed...
My father is getting quotes to have his back-boiler replaced. The firm he wants to use have told him that they will have to fit drain-offs to...
