Discuss Heating won’t come on after draining system in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi, I drained the the central heating, to remove a radiator. After refilling it, the heating now won’t work.
It’s a combi .
I’m getting this symbol
Air locked prob
Turn all but the closest rad off upstairs ideally then stick boiler on with just the one upstairs rad calling for heat
Reply to Heating won’t come on after draining system in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days it's increased whilst cold...is this a regular problem.
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
