Discuss Flexi tails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
notaclue
Hi, I have some new monobloc kitchen taps & they have flexi tails with a female threaded fitting with a flat rubber washer, can I simply screw them to an isolating valve (having discarded the valves olive & nut) ?
Well you can and it will not leak for now but not good practice as the end of the fitting is wedge shaped to take olive and this can cut into the rubber washer over time or sometimes if you over tighten and start to leak, you should connect to a standard male thread end fitting as the jointing face is flat and forms a correct joint with rubber washer on the end of the flexi hose
Can you do it? Yes
Is it recommended? No
Many people do it though, just don't over tighten or the sharp beveled edge will cut into the washer.
Thanks, Have to say, that is what I wondered about!
Not managed to find any male threaded std fittings yet though:confused:
Reply to Flexi tails in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
