- Messages
- 17
I am aware of flues being 300 from an openable window or vent but what if the vent goes into the cavity but not the room inside? Where does that stand?
Discuss Flies from vents into cavitys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes fit new boiler where old boiler was, vent is just under 300m which is the requirement but it only goes into the cavity not the house/ roomWhat’s the rest of the story? Looking to fit a new boiler?
Too closeYes fit new boiler where old boiler was, vent is just under 300m which is the requirement but it only goes into the cavity not the house/ room
Not yet will change vent for bricksToo close
Has it been fitted?
if youve got a vent that just goes into the cavity but not directly into the room you have no idea where poss exhaust could go. just seal itI am aware of flues being 300 from an openable window or vent but what if the vent goes into the cavity but not the room inside? Where does that stand?
just seal it
agreeish depends on the age of the house. most of the old vents wernt sleeved so internal vent could have been already blocked. if not sure where flue discharge could go err on the side of caution, cover your own back and advise cust why you are doing this. . . and install a replacement vent in another location.
Vents are needed to prevent condensation, rot, etc.
Reply to Flies from vents into cavitys in the Plumbing Jobs | The Job-board area at PlumbersForums.net
