Discuss flomasta shower pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
ozzy
Hi I have fitted a flomasta shower pump to a mixer shower gravity, it did work wen I set t up but now has stopped.
I took he pump out and reconnected the pipes with some plastic pipe and had nothing coming through. Disconnected the valve and had water through. Took the elbows off the valve and blew through the check valve in the cold opened but the hot didn't I freed it and put it back together. water flowed ok so refitted the pump all ok until later that evening it wouldn't work again. If the fault is the check valve stopping the pump from kicking in on the hot would that shop the cold as well ?
Any thoughts would be helpful
Ozzy
Reply to flomasta shower pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
