giarc00007
- Messages
- 308
hi guys. went to do a gas safety check today. flue is 300mm from double french doors. i know its 300mm from openable window and vent. But is it still the same for a situation like this?
Discuss flue 300mm from french doors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Door, window, opening, vent! All the same!
A door is a door! Unless it's a RIDDOR! rrr:
Because I can mainly.
I was checking you were still gsr because, if you weren't, we would probably have to rescind your access to the private forum. But all's good.
Reply to flue 300mm from french doors in the Plumbing Jobs | The Job-board area at PlumbersForums.net
